Heater Core
rk.....
For 2 years I drove with great heat in the back, but only cool air coming out of the dashboard. (99 XLT)
Then this year, no heat in rear either. 8-(
Turns out the front heater core was clogged. My mechanic says it will take him 8 hours to rip and strip out my dash and replace it. Wanted 650.00 to do it.
He flushed the core for me, and fixed the issue.
Get the car hot, pop the hood, and find the heater core hoses. There's 2 hoses that go thru the firewall to the heater core.
They are on the passenger side. The heater core is behind the glove box. If one hose is hot, and the other one is cool, the core is clogged or could be bad.
Note that there is a second heater core, its in the rear of the truck, and is accessed from inside, its on the drivers side, above the wheel well. Thats a 50.00 part, he swapped that out in 30 mins.
After parts swapping, core flushing, thermostat replacing we were only getting luke-warm heat.
The top and bottom radiator hoses werent getting hot enough.
Turns out the impellers on the water pump were worn off.
Popped in a new water pump, heat issue resolved!
