cowboy0101
I am a Mazda/Hyundai Tech, But I need to do a timing chain on the listed vehicle above.
When i read the instructions from All Data it says that i need to use the Special Tool for holding the valve.
All I want to do is replace the timing chains,tensioners,phasers and guides
MY Question Is Do I need to do anything to the valve train in order to replace the Components???? Beside holding the cams from flipping. {turning}
The tools it says I need to use As follows:303-1039 valve spring compressor;303-1046 cam phaser sprocket locking tool and 303-448 Crank shaft holding tool.
