CAThrooper
Hi everyone, I am planning to build a roof rack on my '06 XLT, either Unistrut or 80/20 Extruded Aluminum framing. The stock rails are plastic and I'd like to be able to load more weight on the rack than I think they can handle so my first step is to decide how to mount it. I was planning on using the existing mounting screws to attach framing directly to the truck, but that was before I removed the existing rails. What I found is that the existing rails are not mounted in a channel as I expected, but actually on the flat, and also that the existing plastic rails have a nice cavity under them where a gasket sits. I'm thinking if I cut the vertical off the existing rails I can drill holes in the base and mount my framing to that. Then no new holes in the truck, no new gasket material, and no fancy metal working. If I do this, I destroy the stock rails so here's my risk mitigation plan:
1. find & cost a spare set at the junk yard before starting
2. post it here and get you all's input!
Do you think mounting to the plastic base of the stock rails will be sturdy enough to mount a heavy duty rack to?
Thanks in advance for your input!
