You're welcome, I sell them often! (Ford parts guy)Thank you for that part number
Even though money is very tight for me, I’m of the mind it’s better to do preventative maintenance and especially when it’s easier having the transmission out on a bench. I’m very interested in doing any and all part replacement involving ones with known failures and upgraded design parts are available. I’ve seen that the gray auto parts store pump shaft seals fail and to use the black Ford seal only. Also a Ford tech said some were putting a second magnet in the pain because of metal debris working it’s way into the solenoid connectors shorting contacts and setting codes. One video I watched was for 2011 and up 6R80. I don’t know which of the upgrades on that one should be done to an 08. Any other part numbers I should get?You're welcome, I sell them often! (Ford parts guy)
