'08 Exped will not start
broncoremy
North Dallas - TX
The Mrs' Exped left her stranded, it came home on a flatbed TT.
She tells me at home that the Exped had been laboring a little bit to start for the past couple of weeks and it would not crank for her on the road after it died. sounds like a dead battery. took battery to auto zone for load test and it shows as a bad battery. Replaced battery.
Now the Exped will crank just fine, but it will not start.
My next steps would normally be to check for spark and gas, but how?
Then I need to check for any codes. The check engine light stays illuminated, but I did not see it blink.
Thanks in advance for your help,
BR
BTW, that the starter motor ran for 10 seconds even when I released the key freaked me out... I had not run into that before. Owners manual says to expect it.
B
broncoremy
North Dallas - TX
With respect to the check engine light, I just tried it again to be sure and the CEL IS flashing 8 times after I crank the motor. Then the CEL stays illuminated.
01yellerCobra
San Diego
The CEL will stay on until the engine is started. You can still check for codes though. I can't remember if there's a schrader valve on the fuel rail. That would be the easiest way to check for fuel.
There's a feature where you can turn the key forward and release it and the truck will start. You don't have to hold the key forward. I discovered that by accident. And now I forget our other vehicles don't have it.
Misspelling brought to you by tapatalk
Barjrob1972
Have you checked the Fuel Pump Driver Module? This is a common problem on F150's and causes the same problems. I would assume the Expy is designed the same way. They bolt an aluminum module to the steel frame and it easily corrodes.
slhanks4
Gilbert, AZ
Make sure the fuel pump inertia switch hasn't gotten tripped and try resetting it.
stamp11127
Temple, Georgia
Is there gas in it?
She tells you after it dies that it has had trouble for the last few weeks....
JUST4FUN
Admin
Moderator Administrator
Il
see if it will run on carb cleaner if it will then its a fuel problem
B
bedrck46
after you reset the switch and tried to restart did you by chance try using carb cleaner or either to see if it would fire up??
B
bedrck46
take a volt meter and check to see if you have 12V into and out of the shut off switch
if not check fuse #71 and #32 in the battery junction box
you will need to have the key in the on position
B
broncoremy
North Dallas - TX
I checked the fuel rail pressure and found nothing there, so I didn't see if she would fire with cleaner figuring that the problem was no fuel. I need to figure out why no fuel pressure.
I took out the fuel filter, which needs to be replaced anyway, and I get no fuel out of the pump when I turn the ignition to run. I hear what I think is the pump, but I get no fuel from the lines.
Fuel pump, I suspect? I read on here and elsewhere that it is common. Another post mentioned the FPDM. Off to check that now (have to find it first...).
B
broncoremy
North Dallas - TX
Thank you guys for your help.
Do you mean the inertial switch behind the rear drivers side interior panel?
I have 12V to that for a moment when the truck is in the on/run position. As if the PCM turns it on then off - either as normal or the PCM has detected a fault then shuts it off.
B
bedrck46
yes that was what I wanted you to check on the inertial switch If you had voltage going in and out then your problem most likely is the fuel pump. I have had some on here suggest taking a rubber mallet and hitting the side of the fuel tank to see if it would cause the pump to run You may want to give it a try, at the very least it wouldn't do any harm
B
bedrck46
you may also want to check under the expy and see if you are getting voltage to the pump Disconnect the connector and check for 12V on the brown/white and the black (ground) wire just have the wife turn the key to the on position and make sure you block your wheels etc. Safety first.
B
broncoremy
North Dallas - TX
Does the Expy have a FPDM? Unless I missed it, I do not see it listed in the Chilton or Haynes manual or on the wiring diagram.
The parts listing on Rock Auto does not list a FPDM for this model either.
B
bedrck46
I have the ford service manuals and prints for 1997 to 2007. I don't have the prints for the 08 model Looking at the fuse block for a 07 and 08 they are the same so I would take it that the 08 wiring would also be the same The 07 does not show a FPDM also the 2008 F250 wiring diagram doesn't show any FPDM. Based on all of that I would say that you don't have a FPDM however I may be wrong. Hopefully others will chime in.
In the meantime try to check for voltage at the fuel pump as suggested earlier.
