120V AC outlet won't charge laptop
SunnySunshine
SF Bay Area, CA
To shed some light on the mystery on some of you why your laptop charger won't work (including your MacBook charger). Someone on a Jeep forum brought up a good point, apparently Jeeps have the same issue. On my MacBook charger (85W), it says 100-240v 1.5A. So if you have a slightly larger Macbook, it is definitely overloading the built in inverter in the vehicle as 110v 1.5A = 160W, 115v 1.5A = 172.5W, 120v 1.5A = 170W... I was definitely surprised at how inefficient Apple is making their chargers. Ford really need to put a 400W or higher inverter in these vehicles (and Jeep needs to do the same apparently).
I can't believe vehicle manufacturers are wasting copper on something that no one is going to use because it can't be used for any modern day electronics.
