1997 eddie tranny issues
siredzo
boston
i changed the speed sensor, and the tranny TWICE and it still will not shift into a higher gear. and the speedo still dosent work either. So im starting to think there is a elecrtical issue now. but is there something i MIGHT be missing? or is there something i should be resetting?
S
siredzo
boston
im going to pick up the truck from the shop today and ill post that answer later today
S
siredzo
boston
Well I got it back and the speedo and tach now works but, I still have the same issue I was looking in my haynes and I found out that there is a tranny control switch that's on the steering colum and that might be the issue so I'm going to check that right now
S
siredzo
boston
issue fixed i went to the dealer after there were no tranny codes found, it was the tran case motor. i was stuck in 4L and i replaced the tran case and motor myself and my baby is back up and running!!!!!!!!!!!!!!!!
00XLT
Good to hear that you found and fixed you problem
