1998 Eddie Bauer no start
Vlad990
Florida
hey all. Bit the bullet with the wife's kid hauler and tore the dash out to replace the blend door so she could have a/c all around and not just in the rear. My dad finished re installing the dash for me when I was at work today and now the friggen thing will just sit there and crank and crank. Checked fuel pump relay, FIS, and for giggles went ahead and replaced the ignition switch. Damn thing won't run and I really kind of need it for the weekend. Any thoughts?
Thanks
MikeA
Try putting the old ignition switch back in and see if it starts.
Bedrck47
Elizebethtown, PA
Did it start and run before you took the dash out?? If so then I would say that DAD missed something when he put the dash back in.
When you try to start the engine is the anti-theft light blinking rapidly??
V
Vlad990
Florida
I'm hoping that he missed an electrical connection somewhere. I plan on pulling the dash back out and checking over it all and HOPING I find something not connected. It was running beforehand. I don't have a theft Light I don't believe, if I do, then the light is blown because I've never seen it in the 3 years we've owned the truck
docraymund
philippines
Spray starting fluid in the intake and see if it wants to run. And check the transponder key ring electrical connection if snug.
V
Vlad990
Florida
Will not start with starting fluid. Stumbles like it's about to turn over but no dice. Everything around the lock cyl seems tight
Bedrck47
Elizebethtown, PA
If you don't have the owners manual you can go to
owner.ford.com and download a copy it will show the fuse box and also the fuse number
In your expy its fuse # 19 20 amp fuse in the fuse box under the hood
Bedrck47
Elizebethtown, PA
Also check the fuel shut off switch You should have 12 volts at the switch while trying to start You will need a helper to check this if the engine doesn't start the voltage will drop off You may have to check it a few times just to be certain of the voltage
