1st Gen Rear Axle close to Pennsylvania
97_edition
PA
PM if you have one or know where I can get one for cheap. My passenger side rear hub/bearings are leaking and need a new axle.
Thanks.
97_edition
PA
You should look in to a "axle saver" bearing setup. Here's a small write up on it.
http://stangler.com/motorsports/articles/BearingSaver/index.htm
Hmmm... I had taken it to the garage that works on my expy when I can't (I didn't have the time or garage to tackle this myself.)
He had ordered a "different" / "larger?" bearing for the side that was leaking. Not sure of the terminology of this, but he said 9/10 times this fixes the problem. Would that possibly be the same as the "axle saver" or "Bearing saver"?
I will check with him to see if this was the same "fix" he tried. Thanks Tony.
jlused
NJ
We're a auto recycler in Elizabeth, NJ and have two 97 Expeditions. If you still need the rear axle, give us a call at 908-354-3836, we'll give you a very good price.
