2000 Expedition no acceleration. NEED HELP PLEASE!!!
george b
newnan ga
I have a 2000 4.6 ford expedition, just had passenger side head replaced & timing and still has lots of engine shaking. and no acceleration.
stamp11127
Temple, Georgia
We!come to the forum but we need more info on the truck. Miles, why was the head changed, codes, professional mechanic or Bubba work on it etc.
G
george b
newnan ga
there was tapping noise coming from the engine and I had a guy from autozone look at it. said it sounded like a timing issue because he has the same engine in his f150 and I verified this and saw the same engine in his truck. he has rebuilt his engine and he can do my timing for 250 plus parts. we found out the camshaft was all chewed up and decided to replace the passenger side head as well as timing kit. replaced all gaskets as we went along. the truck would not start at first then we unplugged camshaft position sensor and it started but sounds real rough. bought a new sensor and no change. engine just shakes with no acceleration.
stamp11127
Temple, Georgia
Ok.......
1st question is - what chewed up the cam/head?
2nd question - what condition is the other head in?
3rd - what happens if the cam sensor is plugged in while the engine is running?
G
george b
newnan ga
the other head has no issues. camshaft is all intact. metal is still shiny like new. the bad one was worn down possibly caused by 2 rocker arms that had fallen down. when the cam sensor is plugged in the engine stalls out.
G
george b
newnan ga
nobody has any ideas or suggestions or heard of these type of problems. I really need this truck up and running soon as is my only mode of transportation. Please help
stamp11127
Temple, Georgia
Look at it from a logical perspective:
1) engine was running but had a tap
2) head swapped & new timing kit
3) now engine doesn't start after repair
4) disable cps & engine runs but runs like crap
5) connect cps and engine dies
Trouble is related to the work performed. It can be as simple as a pinched wire or as bad as the cam is out of time. If the cam is out it should show up as low compression on that cylinder bank. (Hope it isn't this)
When he changed the timing chains did he lock the cams in place? Once the chains were on, did he rotate the engine at least 4 revolutions to check for interference?
Where did you source the replacement head?
Also, sometimes we reply quickly other times it may take a day or two - it depends if we are busting knuckles on projects.
G
george b
newnan ga
Ok. Thanks for your advice and info. I'm still going to take it to a shop and see what they say.
stamp11127
Temple, Georgia
Why waste our time if you are going to take it to a shop? That time could have been used for other members problems.
G
george b
newnan ga
my intention wasn't to take it to a shop. I was looking for suggestions that might help my situation so that I might fix it myself. So out of 223 reviews on my post, you are the only one who responded and from what I see on this forum, the most of peoples problems were cosmetic "what size tires should I put on" or "what's the best stereo would be best for my truck". These are not real problems. This is my only family vehicle to use without it I'm dead in the water. So thanks for the helpful info you've given me thus far but I will be replacing the engine this fall. In the meantime I'm looking for temporary ride. Good luck with all your real problems.
