docraymund
Good day, my 2000 expy 4.6L is having a misfire. It is still drivable even with the a/c on but recently the misfire became worse after running for about 20 mins. If you turn off the engine and restsrt it, it runs well again. Trouble codes were:
1. B1428 GEM lamp seatbelt circuit failure
2. B1869 PCM lamp airbag warning indicator circuit open
3. B1892 PCM Airbag tone warning indicator circuit failure
4. B1318 PCM battery voltage low
5. P1000 PCM OBD system readiness not complete
6. P0171 PCM system too lean bank 1
7. B1676 ABS/TCS Battery pack voltage out of range
8. B1318 GEM battery voltage low
9. B1352 GEM Ignition key in ciruit failure
Any ideas will be much appreciated. Thank you very much!
