Skylar Palmer
the oil isn't milky its fine just the coolant
You can get either Ford or fel pro for the gaskets, buy a complete set, you'll need all of them even the oil pan. Debris from the chain guides gets on top of the oil pump. Depending on the damage you might want to consider a reman Ford or Jasper complete engine. Head gaskets can be easy or a total mess inside, you'll have to tear down and inspect first. Your mileage is relatively low so you might be able to figure out why your overheating/ exaust gas problem happened, do a head pressure check for cracks, a valve job on heads, and slap it back together. On any overheating job, new thermostat, upper/lower radiator hoses, water pump, and radiator clean out/ replacement. You don't want this scenario a second time. Do it right once and be done with it!
Your upper radiator hose should get firm after the thermostat opens.... it shouldn’t be bloated but it’s normal for the hose to get firm as the engine warms. It will also stay pretty firm for a while after you shut it down as the engine is heat soaking at that point and pressure builds in the system.
The only reason I included Jasper is more than a few members here have had good luck with their remans. If you think of the other quality motor, please post it!
... . .... , , , , ,???ok my other question is on aftermarket tuners and i know when ford made them in 2000 the computer was written a certain way and a guy in Alaska in he does diagnostic and i brought the subject of tuners and he ask me why would i need to get a tuner and i said to calibrate my speedo and he says aftermarket tuners are a but to try it he said sometimes they work and sometimes you have to get 5 new computer and have it re flashed has anybody used a tuner on a gen 1 expedition i was looking at the edge revolution tuner hate to spend $600 and change it and have it **** up my computer and have to spend 2k to get new computers to get it re flashed
