I sure hope I can get some help on this one... It's Our 2003 5.4L (XLT)
SYMPTOMS:
- Will periodically stumble and die. Usually early in the trip.
- Will usually start right up and run normally (and often stay good for several days)
SEEMINGLY UNRELATED SYMPTOMS:
- The traction control has been activated on a normal day on dry pavement and I felt the pulsing of the brakes. After turning it off and restarting about 4 minutes later, NO PROBLEMS. The traction light also did come on.
WHAT I HAVE DONE:
I FIRST replaced the DPFE because one post/tube was broken. Replaced the hoses.
I NEXT checked the MAF for any debris, and used MAF cleaner.
The problem persists (if it's a little less frequent, it's not yet obviously so)
No engine light (sadly). It's NOT throwing any codes...
I tried to capture them with my BAFX bluetooth reader. Nothing.
ALSO: I'm frequently logging data while driving in case it catches something. The MAF readings look right. They did not dip just before the problem... they only dipped after the engine stumbled (such that I cannot really tell any cause/effect).
MY GUESSES:
It could be some central wiring, maybe specifically to the engine computer, OR could be the computer itself, causing one or both issues. It certainly could be two issues. But here's the problem I see... it has zero issues or stumbles until this happens, then it often takes only a restart (often turning all the way off first) to run normally. Thus, it seems electronic.
I may try a better OBDII reader, but I really don't think I'll find anything there unless it's any disruptions in airflow and/or fuel flow. If the computer is malfunctioning, it may not detect that anyway. I'm at a loss so far, but will keep debugging. I'd sure appreciate any thoughts.
SYMPTOMS:
WHAT I HAVE DONE:
MY GUESSES:
