FordGate
Right front tire going bald - wasted 3 tires so far...
I have had my right front tire replaced 3 times. I have had the car aligned 4 times. Each time they say it is fine but do it anyway. 4 different shops. The right front air shock is always low, leaking and is always trying to inflate. Would a defective air shock cause the outer edge of the tire to wear out?
I just got the Suncore kit for $489.
My air ride works ok (96k on the Expy) but the front right is constantly running/filling so I assume it is leaking. Also we are about to replace the tire on that corner for the 4th time due to the outer edge of the tire being worn down to threads again. I have had it aligned at least 4 times so I assume it is due to being constantly low from the air bag leaking. Can anyone speak to tire wear due to the shock being low?
Are there any gotchas with this conversion? I don't doubt I can do the work but just looking for the experiences of others. The sticky only addresses the 2002 which I am told is fairly different from other years.
And again my main concern is not going through tires every 6 months.
Thanks in advance for the help!
