Thanks a lot for the suggestions guys. Really appreciate them.
Update: Got a vacuum pump tester and checked both hubs. Thankfully they both disengaged when a vacuum was applied. Great so at least they work and don't need replaced. So I went ahead and got the solenoid because I'm and instant gratification kind of guy and I figured that since both sides were good that it was pretty logical that the valve was the most likely culprit. Plus it was a failure waiting to happen and got the TSB part with the hood. Installed it... no change. grrrrrr.....
Ok so I started checking the lines with the engine running and noticed a very slight audible hissssss when coming from the 3 way check valve downstream of the the solenoid. So I pulled the hose and noticed there was no vacuum on the solenoid side of the valve but there was on the other side. Ok, so I removed the valve and put in a T-connector and VOILA! both front wheels freed up. Awesome! Problem solved, bad 2 way check-valve, right? Not so fast, I tested the check valve and it seems to be working correctly. So now I'm really confused. I think the PO or another tech may have installed the valve backwards but I need a diagram that shows how the vacuum system works to know for sure. I don't think it's the check valve downstream of the solenoid because with the T in place everything works correctly.
One thing I do know is now I'm on the right track and with the hubs unlocked the Expy drives like a totally different vehicle. I'm no longer spinning 2 axles and a driveshaft so the vibration is gone and I'm hoping I'll recover a little more gas mileage. I just want to get the system operating the way it is supposed to.
Any further help is greatly appreciate. Thanks!
