2004 5.4L - Removed Transmission. Engine Rocked Back?
Maryland
Long story short... I have a 2004 Expedition 4WD with the 5.4L. Broke the direct clutch drum in the transmission, so it had to come out. Before this one, I'd never removed a transmission. I read a ton of forum/blog posts and watched some youtube videos... and overall, I'd say I did fairly well.
My question relates to the engine and more specifically, the engine rocking back after the transmission was removed. At first, I mistakenly thought that the y-pipe in the exhaust had to be removed in order to get the transmission out. I knew the engine rocking was a possibility, so I wedged a piece of lumber between the bottom of the oil pan and the cross member. Then I separated the exhaust just before the muffler and the entire assembly dropped down about 2-3". I checked the engine itself and it had obviously rocked back some... I'm just not sure it's the full 2-3" that the exhaust moved. So my question is this...
What (if anything) have I likely broken/damaged by allowing the engine to rock back? Up top, the throttle body and hoses and whatnot definitely got closer to the firewall, but I don't see anything broken and I didn't hear anything crunch. My primary concern is fuel lines and brake lines as these are mounted at fixed locations along the frame. If the engine moves and the lines don't, will they bend or are they more likely to just break?
Obviously, when I get around to reinstalling the transmission, I'll do a visual check on all of the components. I'm just looking for pointers from those with more experience about what items I should really focus on checking. If I ever have to remove this transmission again, I know not to disconnect the exhaust. Life lesson learned!
KyleR
Missouri
You'll be fine I let mine sag to reach the top bellhousing bolts easier, and I'm pretty sure I had to remove my exhaust as well. Been driving mine for over a year no issues and also done an Explorer and Mountaineer that way.
1955moose
I've pulled my share of Automatic transmissions over the years, and I don't ever remember supporting the engine. Front wheel drive vehicles have a sling that needs to be used to support the motor, but theirs ways to get around that too. I wouldn't worry too much. Just keep an eye on things over the next week after reinstall of Transmission.
stamp11127
Temple, Georgia
I've always supported the engine by placing a 2x4 at the back of the oil pan with a hydraulic jack under that. There is a bunch of plastic on these engines now, you don't want to bust any of it.
stamp11127
Temple, Georgia
stamp11127
Temple, Georgia
