stamp11127
Double check trans fluid level, make sure the correct fluid is used. These are hydraulic systems and operate on the same principle as hydraulic construction equipment. If have have trouble with the hydraulics then things usually stop working correctly.
After the fluid check and still not operating, the trans pump is probably toast. Rebuild time.
Tail housing and tail shaft should be different between the 2wd and 4wd trans, can't verify that though since I haven't had those apart.
