2006 Expedition starting issue...
bones281
Houston,Tx.
Ok this morning I went out to start my 2006 Expedition and as I turned the key there was a click click, then a slow crank, then click click panel lights and head lights all dim. After several try's it started up and ran just fine. I drove to work and at lunch I went out and the something happened, after letting it run for about twenty minutes I shut it off and restarted it without any problems. However when I got off work this evening the whole thing happened again. I'm just wondering if this could be a battery issue or something more in depth.
FordandPolaris
Saint Cloud, MN
Can you check the voltage you get at the battery while it is off as well as on? I don't remember what is too low, but I would say if it is not above 11v while off (and not many short trips or starts without driving much, this would drain the battery without allowing it to recharge) I would replace the battery.
When was the battery last replaced?
B
bones281
Houston,Tx.
I'll have to find a way to check that, but I do only work less then two miles from work. most of my driving are short trips.
FordandPolaris
Saint Cloud, MN
I'll have to find a way to check that, but I do only work less then two miles from work. Missy of my driving us short trips.
Here is what I would do, just so you know the battery should be sitting on a good charge. Start it and drive for 20 minutes or so. Come home and leave it overnight, check the voltage right after driving it and again in the morning, if a significant change is seen, replace the battery. Multimeter is probably 20 bucks at a local hardware store.
Or, since its good to replace the battery once every 3-4 years, just get a battery ($80) and see if that helps. Have you owned the truck since new and if so, has the battery ever been replaced?
B
bones281
Houston,Tx.
Seeings how I bought it used in January and there's no real way to determine if the battery has been or when it was last changed, I'll go ahead and get a new one.
Yudaman
Southern Oregon
Sounds like textbook battery failure to me. Replace it and the issue will go away with the old battery.
FordandPolaris
Saint Cloud, MN
get alternator checked too
If the alternator was bad, the truck would die while driving. If you end up purchasing a multi meter, the battery should be charging at 14v while running, so if it is less, you could have a bad alt. Start with the battery though.
Also, some batteries will have the date they are purchased labeled on them. I'm sure you already looked but it could be there.
B
bones281
Houston,Tx.
Well went and had the alt checked and she's putting out 14 vlts and I had my battery checked (after driving twenty miles to the parts store) and turns out the battery was bad. So I went ahead and bought a new one... Thanks guys.
