2006 Expy EB - Puddle lights staying on w/LED lights
SFTX
I started converting all of the lights on my Expedition to LED, and for the most part things have gone well. I do have one issue though: my "puddle lights" (the white downward firing lights on the mirrors) stay on anytime the car is running. I followed someone else's writeup and replaced the flasher relay with an EP27 LED compatible flasher. The relay is located behind the glove box on a 2006. That fixed the rapid flash issues with the turn signals.
However, the puddle lights stay on when I'm driving. I don't think they did before I switched things out for LED lighting. They do turn off when I turn off the car, so I don't think it's an actual electrical problem. Page 276 of the 2006 Expedition owner's manual lists relay 2 as the item I should replace (I think?) But that slot is empty in the fuse box, probably because they relocated it to behind the glove box (as mentioned above).
Do I need to splice in resistors? Did I miss replacing a relay? I'd really rather replace a relay or other component instead of splicing in, but I need to solve this issue somehow.
1mpg
In a house
Did you ever find a solution to this? I have a similar problem with one of the rear passenger dome lights. I recently converted all interior lights to led lights and that one specific dome keeps that led bulb somewhat on (not fully on) when the truck is off.
Newport News, VA
ALL my lights are LEDs...never had that prob and I have the LED flasher...check ur light delay settings...
