2006 Stereo Harness issue - Crutchfield Stereo Replacement (double din)
J
jmacres
California
I'm on board with getting this in place to stop the popping. Crutchfield shows this doesn't fit my 06? I will give them a call
Thanks for all the replies!
04EddyExpy
Columbus, OH
I bought a touchscreen CarPlay stereo for my '04 from Crutchfield and I had nothing but nagging issues with it for over a year.
After the head unit was installed with their wiring harness, certain FM stations would produce static if I used the turn signals or stepped on the brake. My turn signals would speed up or slow down at random. I never heard any of the popping that's being talked about, but after a year the antenna adapter started having issues.
I finally got fed up, ripped the whole damn thing out and sold it lock, stock & barrel on Facebook. I put the original factory stereo back in (has the 6-disc CD changer). I still have a little issue with static and the turn signals, but it isn't as bad. I'm starting to think those gremlins are related to the LED flasher and LED turn signals & brake lights.
R W Carpenter
Raleigh, North Carolina
I had that same harness in my 2006 EB, it didn't stop the sub pop, even adding an AFDI-5V before or after the crus converter, and trying a second AFDI-5V, I still had pop. I switched to a metra harness (with and AFDI-5V) and Axxess SWC and the pop went away. Both the Crux and Axxess SWC sometimes makes my volume go up instead of down if I push the volume down button.
I haven't had an issue with sub lol. Guess I got lucky.
R W Carpenter
My LED turn signals speed up once in a while too.
Don't get me started on the issues I had getting my LED headlights to function properly.
04EddyExpy
Columbus, OH
I gave up on LED headlights. One would flicker for about 10 seconds after shutting off the lights and eventually burned out the LED within a few months. Insane. Never burned out an LED before. :)
Not to mention the stock headlamps aren't build for LEDs. They refract & scatter the light. You can see roadsigns pretty well but you also blind other drivers. Projectors are where it's at for LEDs, but they're expensive. So I stuck with Sylvania SilverStars in the headlights and put LEDs in everything else - interior lamps, side markers, brake/reverse lights, fogs, and high stop brake light. Getting ready to do the little ones over the license plate also.
R W Carpenter
I know what you mean about the flicker. My passenger side headlamp flickers when the truck is off periodically. I have had to replace the bulb once already. Lifetime warranty thankfully. Next time it burns itself up I may switch over to HID for the lows and leave the LED in the highs since most of the time I'm not driving into oncoming traffic when they are on.
sharprd65
