2007 expedition
doug1953
What is park aid and how dose it work the on/off
Bedrck47
Elizebethtown, PA
if you have you owners manual I would suggest you read it and it will explain It will also give you maintenance sched for replacing plugs
01yellerCobra
San Diego
If they haven't been done then now is the time to do it. Ford rates those plugs at 100k, but the two sets I've pulled at 50k were toast.
tpndrcn
Morrison, Il
Park aid is a reverse sensing aid that will beep at a faster/slower rate based on how far away you are away from something when backing up. It can only be shut off in when you put it in reverse and select it to the off position ,otherwise it's on.
