Bedrck47
yes your question wasn't very clear You mention expeditions and also mentions explorers so that made your question confusing
Then you mention 2007 and up yet you give no information as to what year your expy is
As I posted Ford has made changes in the system on the 2009 which is different that previous years and the 2003 thru 2008 all used the same fuel control with the exception of the 05 and 06 which uses a FPDM
Basically the fuel pump get it power thru the fuel pump relay which is controlled by the PCM relay and PCM
The system from one year to another year do change at certain times That is why it is important when asking questions concerning electrical circuits to know the year that you are asking about
also keep in mind that this is a forum about Expeditions. Although other questions may and can be answered When given the correct information. What I say about the FPDM is for expeditions even though Ford has used the FPDM is other models and other years
