For an existing roof opening panel motor/module:
• Press and hold the open switch until the roof opening panel glass moves to the full OPEN position.
• Press and hold the open switch (for approximately 10 seconds) until the roof opening panel glass moves past full OPEN, then back to full OPEN. Quickly release the switch.
• Press and hold the open switch. The roof opening panel glass will move to full TILT, then back to CLOSED (initialization movements). The initialization movements will start within approximately 3 seconds after the switch is pressed
Release the open switch and test the system for normal operation by carrying out one-touch open to comfort STOP, full OPEN, close from full OPEN to full CLOSE and TILT operations
