gixer2000
Retrofit or Bust
You should watch the second video! Hundreds of leds on the table that they have tested so saying they didn't give the others a fair shot is crap.The first comment on the first video says it all. "Let me guess...the headlights you sell will perform the best and all the competitors will suck." 214 thumbs up and 0 thumbs down. LOL! I would counter Headlight Revolution with which bulbs did they test against? There are a lot of low quality bulbs out there for sure. If they just picked random bulbs most are bound to be crap. It's up to the buyer to pick the best one based off reviews and research. Regarding some of the light beams in the first video I don't think it's a fair assessment because they don't look to be installed correctly. Take the one that is "scattered and too high." The "expert" says "you'll blind people." Well, no kidding. That headlight needs to be aimed down for sure. Different headlights will require different aim. That's a given. There were other beam patterns that were weak or the light was off different directions. That is a bad install as well! The light is that way because the LED isn't directed properly. I had a similar beam pattern on mine until I rotated the LED to direct the light properly. My LEDs can rotate 360 degrees to get the beam focused just right for the housing. So this "expert" isn't installing or aiming these properly. I didn't watch the second video. Who has 30 minutes to watch a video about headlights? If your "expert advise" and "facts" are coming from this guy, I am beginning to see where the problems are.
(mike drop)
Headlights should NEVER have to be aimed down out of factory specs to avoid blinding other drivers. If the bulb maintained the same optics as the original bulb they would be spot on but since most leds don't people think aiming down is the righr thing to do.
For the record NONE of my information comes from HR and this was just a visual I found on YouTube so people could see the difference.
(Mic drop)? Might wanna pick that back up because you've proved nothing!
"My LEDs can rotate 360 degrees to get the beam focused just right for the housing"
Show us!
