2010 low fuel light
sub0cool
Pikeville, Kentucky
I have a 2010 Expedition el and have been having problems with the gas gauge and low fuel light coming on. I figured since I had 118k miles on it, the problem was probably the sending unit. Changed out the pump assembly and I’m getting the same thing. The fuel gauge will work fine some days and others I will get a low fuel light and the gauge will slowly fall down. Take the battery terminal off and it’s back to working for a while. Does anyone have a wiring diagram of the grounds for this. I have cleaned and reattached the ground to the body on the battery ground. I think a bad ground is the issue.
ManUpOrShutUp
PA
Airbag, PATS, fuel sender and transfer case ... I don't see any shared grounds for those on the diagrams.
S
sub0cool
Pikeville, Kentucky
Airbag is a weird one. My key that I use causes PATS, it broken hardly use it . My transfer case if from the winter when trying to go to 4 lo, got the wrench on cluster and wouldn’t go to 4 lo. 4 auto works and it seems like 4 hi works. Probably a motor on transfer case that’s not moving right. Replaced the fuel pump with a motorcraft branded one. I’ve cleared the codes will get back with the new codes it’s producing.
JamaicaJoe
Oviedo FL
Dont dismiss a weak battery for all kinds of weird problems.
Sent from my SM-T350 using Tapatalk
M Bennett
