anybody know if the wiring is already there? I could pull the panel and check - but figured one of you guys may have done it already. I am probably going to just put an oem one in if it is already prewired. Thanks, Mike
just trying to add the factory sub. my xlt does not have a subwoofer and i miss it from the other Expy. I was going to buy the factory amp/sub and put it in there and was hoping the wiring would already be there. I like the factory one because it is completely out of the way. I have not seen an aftermarket one for an 11 standard length that goes in that spot.
911Jason-I have a standard length Expy, have not seen a prefab for it (would definitely consider that instead) , I want to try and keep stock appearance because when we travel, we use every inch of space in the Expy. I have 5 10"s and 2 12"s laying around and amps from a past life, but priorities have changed (I may still just end up throwing a single 10 and an amp in there-but I was looking for the easy route-plug it in and be done.
I totally forgot the stealthboxes are for EL models only. I have a 10" sub in a sealed box sitting in my cargo area, with a 5-channel amp inside that panel where the factory sub used to be. If I had an endless supply of cash I would buy the stealthbox and then probably move the amp either to under the 2nd row seats or into the tray area under the rear cargo floor. Not sure if it's big enough though.
Freeway - you wouldn't want my amps. I have been fortunate that they are the same ones I have in multiple vehicles for over 15 years. I even have a couple of other ones that are in friends boats. i have just been lucky with them, but they are not pretty. I think I have all of my big ones loaned out right now also. I only kept two small ones (one is going in the boat, and it appears the other one may be going in the Expy). Then I have one other little one that used to run rear fill speakers in my Grand Cherokee. I may just end up throwing a single 10 I have in a sealed box in there for now. If i find out the wires are not there.
That would be too easy.I really appreciate the response. I went out to the 2011 Expo and the woofer harness lead that is present is not present on the 2014. So, in short, it seems that if your vehicle did not come with a factory sub, there is no awaiting harness to pop a factory sub in.That would be too easy.
