Trainmaster
Old School Member
Buy the $10 China coils and you'll be chasing the problems from one plug to another for as along as you own the truck. Change the plugs first. If a problem persists, find out which cylinder has the problem and diagnose it.
Switch the problem coil with another cylinder and see if the problem follows it. If it does, replace that one with an OEM Motorcraft coil. If it's not the coil, check the connector, the injector then do a compression test.
Unlikely to be anything more than the plug. Perhaps a coil. Basic stuff, my friend. Always feels like the tranny when they start missing at speed.
Oh yes, when you buy plugs stay away from the Amazon counterfeits or the parts chain Torque-pro or other creepy brands of junk. Buy Motorcraft plugs.
