2013 EL Limited squatting when towing
IdFamilyTruckster
idaho
Already got a weight distribution hitch (correctly setup). Was trying to find an option like Sumo Springs or Timbren SES but it looks like neither of those are available for my year / model. Any ideas would be greatly appreciated. Something like sumo springs or the Timbren SES would be great because it could be DIY instead of the local suspension shop. Thank you in advance
JasonH
Houston, TX
You shouldn't have any sag if the WDH is returning enough weight to the front axle. Have you been to a scale? Did you measure 50% front axle restoration?
I
IdFamilyTruckster
idaho
Unfortunately we don't have scales nearby. We are pretty rural. Without any load or anything our front end usually sits 5 inches above the wheels, our rear end usually sits 3 1/2 inches above the wheel wheels. With the weight distribution hitch we lost an inch and a half in the back in the front went up a quarter inch. So it looks a bit squat. Just wanted to see if anyone knew of any products that we could get similar to sumo Springs or Timbren SES but they will actually work with our rig.
I
IdFamilyTruckster
idaho
Is this not legitimately what this site is for? To ask questions of other expedition owners? I own two expeditions. Is this not a legitimate question?
Stephen Dunster
South Carolina
I have a 2013, but it is not an EL. I ordered Sumo SuperSprings CSS-1168 from Amazon and put them in 3 years ago to lift sagging rear from weight of my tools. The part number 1168 is from the height of the insert, 1.68". There are multiple sizes available so you can measure the distance between your spring coils and find what will work on their web site. https://superspringsinternational.com/coil-sumosprings/
JasonH
Houston, TX
You don't need a scale for this. You measure the gap before the load is placed on the tongue. However much the front rises, you want to cut that in half when the WDH is hooked up. So if the front rises by 1 inch with the tongue load, that should be 1/2-inch when the WDH is hooked up. Otherwise you're not restoring enough weight to the front axle.
NorthernExMax
United States
my 11 limited (MAX, though that should be the canadian version of the EL if my info is right) has rear air springs, and i am unsure if that was standard equipment at the time. With a 2in difference between front and rear (and the front being higher even still than the rear) with NO LOAD, it sounds like you need some replacement parts. Not much info on your equipment, but the shocks regardless could be bad, which would cause your rear end to sag. If it has air suspension in the rear already from the factory, it should automaticly adjust.
We need just a little more information to help ya here. Also, if you do have the coilover traditional struts then you would have to add an external airbag, or just replace.
chuck s
The purpose of a WDH is to distribute the trailer hitch load to both axles. Level towing is an effect but not the cause. Original post measurements indicate weight has been removed from the front axle. Put some more on it and the rear should be lighter.
You can eliminate rear end sag by replacing the rear shock absorbers with solid steel bars (or 4x4s) but these don't really help. Nor do kludges line stuff rubber thingies wedged in the suspension nor stiffer springs. Cosmetic -- level towing is not the goal, weight distribution is.
Mine is pictured below and looks level enough to me. :)
Photo of yours would help.
-- Chuck
Cruk
Alabama
If the front went up, the WDH is not set up correctly. The hitch should divide the total hitch weight between the the front, rear and trailer axles. For example, if you have 900 pounds of total tongue weight, you should end up with aproximately 300 pounds on all the axles. The additional 300 pounds on all axles would bring them all down, none should go up. Are you sure the ball angle is between 10-15 degrees and have you shortened the spring bar chain links to the brackets? You should have to raise the the trailer tongue and rear of the vehicle around 4” when connecting the spring bar chains and then lower the tongue jack until the full weight is on the WDH. I have set up manyWDH in the past thirty years and what you are describing should not happen.
Cruk
Alabama
Level towing is the goal, and weight distribution is the first method before modifying the vehicle, which should be avoided strongly. Usually if level towing can’t be achieved without resorting to vehicle changes, it’s a indication the vehicle is not large enough for the task.
2010ELExpy4x4
California
What is the weight of the trailer to begin with, there should be a label on it somewhere.
We tow a 6800 lb 30ft unloaded weight, using a 1000/10000 WDH. You may need to make more adjustment to the hitch.
The EL max tow is around 800/8000 (without tow package) which once you load trailer and vehicle kinda taps it out. You can get sumo inserts, they didn't work too well for us. We were camped out in 120 degrees, they softened so much one of them pushed it's way out. (at least that's what I think happened).
mjp2
Howell, NJ
For my 2010 EL I contacted coilsprings.com and had them make a custom set of coils. Price was in line with factory off-the-shelf coils.
For my setup I went with +1" ride height and coil spring rate of 900#/in compression. Mounted on Bilstein 5100s it rides great whether empty or towing.
chuck s
Level towing is the goal.
Proper weight distribution is the goal.
Lots of ways to achieve "level towing" but still have poor or unsafe weight distribution. Proper weight distribution should cause -- result in -- level towing but level towing doesn't cause proper weight distribution which IS the goal.
-- Chuck
NorthernExMax
United States
Towing course for dummies-
Install weight distribution hitch for equal weight. This does not result in a level tow, unless the weight loaded onto the vehicle is within the original specs for ride height.
Level towing- this is achieved through the suspension dynamics, most easily through air suspension (redirecting weight into the chassis and front axle, or having an equal amount of pressure at each wheel if 4-wheel air suspension). You can have level towing WITHOUT a WDH, if you have air suspension. Without, it would be impossible to have truly level suspension. Most vehicles with traditional coil/leaf springs have the rear raised up during normal unloaded operation, to accommodate such load that they are safe at high speeds due to being level.
TLDR: get a WDH, set it up correctly, and still have some sort of sag. Add air suspension, or get something with air suspension already equipped (this DOES NOT increase towing capacity by the way) and you can achieve a completely level vehicle (expedition) with either 10,000 pounds or 2,000 pounds behind it.
Nick630
ohio
You could go on harbor freights web page and get the manual for their wd set and follow that, Thats what I did and it worked fine, with a 10000 lb wd, 1 1/2 inch squat in the rear and 1 inch in the front with a 7000 lb trailer.
