2013 Limited with oil on front upper radiator only.
franclynstauer
michigan
Hello I just noticed there is an oily smudge collecting on the right (passenger) front side of radiator and I cannot tell where it is coming from. I dont see anything on back or on fan. There is nothing on the driver front side it is fairly clean. AC blows cold. No oil in coolant. Where is the condenser located on 2013 flex fuel ? Could it be AC oil ? Thanks
GlennSullivan
NY & FL
When you say front, I assume you mean facing the AC condenser and away from the engine. If so could be oil from refrigerant, is it sticky? Inspect the condenser to see if you can see any leaks.
bodabdan
River Valley AR
Had the same issue. Power steering cooler is built into the a/c condenser, all the same piece. Mine was leaking at the top corner, passenger side.
