2015 ecoboost temp sensor
Pilgrim
SK. Canada
2015 with just over 100,000 miles. Temperature gauge normally reads about midway. Recently started randomly going to bottom, then back to middle as driving. Then "coolant overheat" message appears in the message center. Truck is not running hot and appears sending unit is faulty.
Here's where it gets interesting.... sender is screwed into back of passenger side cylinder head at the bottom, just near bellhousing. It is, so far, impossible to reach with engine installed. I've tried from top, underneath on hoist, and removed tire and fender. Can just see it through fender but can reach it with a hand. Connector needs to be unplugged, then sender threaded out.
I'm ready to burn it to the ground! Pulling the engine is not a reasonable solution to replace $20 sender!
Any helpful ideas?
coolzzy
Idaho
Maybe it can be reached if you put the truck on a lift?
emtmark
This has been said for the last what ten years of the Ford let’s fix the motor after we remove the body strategy?!
6.0, 6.4?!
Take the truck off the Frame and repair
