2015 EL Platinum with 22s and CCD...Liftable?
Neil T Casey
Ive been going through these threads for a while now and stumbled on some commentary tonight that confused me. It said Expys with the CCD are not liftable. Is this true? I have reached out to readylift to see if they can answer this as well.
I can fit the 305/45r22 tires on the truck as is, however I leveled my F150 and really would like to do the readylift 3/2 option if I can.
Thanks!
Neil T Casey
Neil T Casey
Ill answer my own question. They are liftable and its super easy. Same as std suspension but you need to flip rear shocks to the opposite sides due to the CCD module and cable length since the spacer flips the shock 180. The links in the front go from 4" stock to 3.25" and the rears go from 4" stock to 4.25". I also had to drop my abs bracket to keep the line with enough slack at full extension. Very happy with the outcome.
Neil T Casey
Neil T Casey
@Linksvu
Yes I did the readylift spacers. Turned out pretty good. Didn't see the 3/2 height improvement more like 2, 1.5, but it looks noticeably higher and is basically what I wanted. There are a ton of 18+ w/ CCD lifted as @Miekk posted above, but for the 15-17s I really didnt see many if any in our forum that had done it.
3tonsoffun
@Linksvu
Readylift 3/2 on my 16 got me 2-3/4” and 2” respectively, top thatvwith 35/11.50s and she’s a solid 5-1/2” taller than stock. 8B0511AA-90A0-4634-9FBB-CFBA778B377B.jpegD7FBFF85-C04A-43C7-BF42-F935332833A9.jpegEE0D3884-D301-4CAB-8F2A-0B8F99F40044.jpeg0150387E-F56C-4719-AE4A-D4F0DE0845CF.jpeg7342E19A-7AE9-462C-81EB-2B167F51AFE2.jpeg
wiscoford
