2016 Expedition Headlight Assembly (Help)
Bibin Philipose
Dallas
Looking for an aftermarket Headlight Assembly for 2016 Expedition EL... found few for 2014 year model just curious if anyone know if it will fit on my 2016 thanks!!
Anthony DeVor
Maryland
No because 1: The 15+MY uses a hard to find 4 pin plug that has low beam, high beam, running light and ground all combined. The 14-MY has a 3 pin plug (low, high, ground) for the headlight & a 2 pin plug for the side running light.
Otherwise I don’t see a reason as to why it wouldn’t work. I did find the headlight plugs for 15+ on mouser and can include the link later for if you want to buy them but you’d also have to buy a side marker light because the 15+ come with them built into the housing where the 14- has a twist in socket
