2016 Wheels from an F150
Agkoh2011
Maryland
Forgive me if this thread is already a thing somewhere. Feel free to remove if so.
I have a 2016 Ford Expedition XLT. I am looking at picking up some used wheels (on the cheap) for a Second set Winter/Summer. Do any of the Ford F150 Wheels fit the 3rd Gen (2016 in my case) Expedition? Any good resources to look into for research?
Thanks,
Agkoh2011
sjwelds
Kansas
Yup. Any 6-lug Ford wheel should fit.
You might have to trim the end of the axle shaft on the rear.
A
Agkoh2011
Maryland
Sjwelds, hmm. Not sure I completely understand that, but in an event, I would want to avoid that. Ideally I would keep my Stock wheels as my Winter Set and my newly acquired wheels as my Summer set. So trimming down would probably not be a good thing.
If I understand tire stuff correctly, dropping an inch in width does not have any detrimental affects, but Im not sure if thats true with the same offset.
bloodhound
Merica
The F150 wheels have a different backspacing. So your (rear only) axle shaft will slightly poke through the F150 center cap hole not allowing the caps to be mounted. The solution is take a hack saw/sawzall or cut off wheel and trim a little off the end of the shaft. Its very easy and doesn't hurt anything.
A
Agkoh2011
Maryland
Ah great. Would it affect the Stock Expedition wheels from being put back on?
1970Maverick
orlando, fl
Agkoh2011,
here are the specs for the Expedition's OEM 18" I have a 2017 xlt but I think it would apply to 2015-2017
MPN# FL141007BA
Bolt Pattern 6-135
Offset 44mm
Wheel Size 18x8.5
Hub Bore 87
these are for an F150. note that the F150 wheel is 1" narrower
Material Aluminum
Size 18" x 7.5"
Diameter 18"
Width 7.5"
Lugs 6
Bolt Pattern 135mm
Offset 44mm
Style 6 Spoke
Part Number FL341007CA; FL341007NA; FL3Z1007K; FL3Z1007C; FL3Z1007L; FL341007PA
A
Agkoh2011
Maryland
1970Maverick,
Right, that seems to be the information I have found as well. After sketching the profile, it appears that the f150 should fit, except for the previously mentioned axle issue (easily solved).
I appreciate the help from everyone and will see what I can find on Craigslist and report back if successful.
r98exp1
