2017 engine ticking noise
khphillips
ATLANTA
I bought this truck used as certified pre-owned. The truck has 40k on it and as developed a ticking sound when cold and at operating temp. Took it to the dealership and the tech says all is well just injectors. The noise very similar to the piston skirt which I have seen on Utube. sounds sort of like exhaust manifold cracked, slack rocker arm, piston slip. The service writer says he will get the shop manager to have him listen to it. I called BS lets open the hood on a new one and see if it makes this noise. Any suggestions?
Is it getting worse with time? That’s an indicator of the piston skirt cracking issue. The DI fuel pump and injectors make some noise but not much so it’s good to call BS if you think that’s wrong.
Trainmaster
Old School Member
Rockaway Beach, NY
Did they open the hood on a new one and listen to it as you asked? Injectors do make a light tap, but you really don't hear them inside the car, just perhaps outside by the hood.
762mm
Quebec, Canada
I've never heard of piston skirts cracking... is that an EcoBoost thing due to the higher operating pressures or higher performance crankshaft?
762mm
Quebec, Canada
This guy demonstrates a test for checking broken piston or piston rings: put compressed air into cylinder bore through the spark plug hole and if it comes out the oil filler, it means there's a problem:
There is a TSB for it on the ecoboosts. It starts ticking and progressively gets louder until loss of performance from what I recall. That’s likely what OP is referring to.
K
khphillips
ATLANTA
As for the progression, I purchased the truck last fall and it made not noise other than the clicking type noise of the injectors which I feel is normal based on my history with fuel injection. I just heard the noise for the lst time last week. I can take to another dealer who will likely not want to do anything either. Should I complain to ford corporate? I await their response this morning. I do plan to video the truck sitting in the parking lot at the dealership --I will post later
jeff kushner
North of Annapolis
Complaining to corp prob won't carry any weight if you don't have documentation from at least one Ford dealer.
I'm guessing that the "ticking" is loud? Like a failing hydraulic lifter loud? Then there is really no reason for them to doubt a problem. If they refuse to find the problem, THAT is what I would approach Corp with.
Hope it doesn't come to that for you though bud,
jeff
mquick5
Buckeye Country
My 79 F150 4x4 came with a 300 6cyl. I cracked 3 piston skirts. And then bought 2 different junk yard motors, that had cracked skirts as well. Then finally tossed on a 351 Cleveland. Solved.
K
khphillips
ATLANTA
update --the dealership says injector noise more completely normal. I will update with the video. I am completely discussed.
762mm
Quebec, Canada
Then they wonder why people sh*t on dealerships and call them "stealerships"... it's experiences such as the OP's.
I think we all had one at one time or another. :mad:
jwas1
Newport News
Is yours a Triton V8? I heard clicking on mine. Service said likely cam phaser. I had been using Pennzoil at Jiffylube. Service said change to Motorcraft synthetic. Clicking stopped and did not return for next 25k until I traded it.
He has a 2017 3.5 EcoBoost.
iamretired
Pahrump, Nevada
I bought a 2015 in march with 83k on it, I didn't notice the ticking till I drove it from SLC I got home in Pahrump,nv and it was in my garage and I started it the next day. I found a tread on here, that explained the high pressure of the injectors, causing the sound from some plastic part housing, can't find that thread but many said was common and dealers that looked into it said it was normal. YOU might want to get an extended warranty, anyway, like I did, 36k, esp I think 100 deductible until 2022, it was like 1600 from Lombard ford.
