My 2018 Expedition with HD Tow package, 62k miles, had cam phasers done about six month ago. Like others, heard cooling fans running hard after running a quick errand. Opened hood, coolant was low, couldn’t see any leaks. Checked engine oil, it was fine. Took to dealer who diagnosed water pump was leaking coolant out of weep hole. Had dealer replace water pump. Drove to Colorado and engine temperature started appearing above the gauge, reading about 234 degrees when driving with my truck rather loaded with people and gear while climbing on a freeway at 75mph with air temperature around 60 degrees. Had similar experience on same trip with vehicle not loaded, driving up 7% grade at 45mph with outdoor temperature of 40 degrees.
The coolant reservoir was filled above the max line from the dealer after water pump replacement.
I have pulled my boat numerous times in 100 degree outdoor temperature maintaining 75mph, never having a problem.
Any tips or comments? I will return the truck to the dealer who did the water pump. Likely they will not duplicate the problem. Since the water pump was replaced under my Ford extended warranty, have no idea if thermostat was replaced.
