2018 Platinum, CCD shocks seem rough, "Drive Control Malfunction"
NyackRob79
Nyack, NY
So far, the truck has 39k miles. Started noticing a harsh ride in the last two weeks. The rear end seems to cause the whole vehicle to shake and reverberate after hitting every little bump on the road. "Drive Control Malfunction" displays on the dash everytime the vehicle is started. Good thing the local Ford dealer has availability in two weeks. It used to be they were backed up for months thanks to COVID limitations on their staff.
Truck is a lease (39mo, 49k miles), although the sales rep assured me LeaseCARE would cover the period until lease end after my factory warranty runs out.
So far the truck has had about $4k worth of warranty work performed due to failed A/C system. If these CCD shocks are in need of replacement so soon, I might be rethinking purchasing this model after lease return.
Will keep everyone updated once I hear back.
dlcorbett
Air Force
tx
Have your tires been changed over the crs of the lease?
N
NyackRob79
Nyack, NY
No. Original all seasons, but they have plenty of tread left. I use winter tires 6 months out of the year.
Rincon, Puerto Rico
This happened to me once after a tire rotation, they left the cable to the CCD unplugged!!! (True story). And the Drive Control Malfunction warning would pop up on the screen and the drive would get rough and choppy... hope this helps
Rincon, Puerto Rico
N
NyackRob79
Nyack, NY
Thanks for your reply. Truck is in the shop today. They're saying there are no codes. Apparently whatever the issue is, it's not being logged. I sent them a screenshot of the message which appears on a daily basis, and truck goes from soft and comfortable to a stiff-as-a-mother. They're saying they can't fix it if there are no codes. I told them to try harder, it's an $80k vehicle. We'll see.
AKentPhoto
New Orleans
Wow...
Pretty sure my first question would be if I could speak to someone not about about to loose their job to a computer?
N
NyackRob79
Nyack, NY
Picked it up today. They couldn’t replicate the problem after driving it for 15 miles.
4 minutes out of the dealership and light comes on for me. Suspension on super stiff setting. No drive mode availability.
Turned around and took it right back. Told they they can keep it until it’s fixed.
AKentPhoto
New Orleans
Did you leave it running to show them?
I bet it's something simple like the harness needs to be unplugged and plugged back in. If it's not instant and happens that quickly. But I'm no expert...
dlcorbett
Air Force
tx
Were you able to get a service tech to ride with you while it was running rough?
N
NyackRob79
Nyack, NY
Yup, left the truck running with the message displayed on the center console. They saw it. They asked under what conditions it occurs. I told them the truth - usually within 1-10 minutes after starting the engine, regardless of speed or gear. If I had to guess, a loose/bad connection somewhere, or a hardware part gone bad.
They don't know what to check because there are no "codes" stored (DTCs).
I told them figure it out.
I hope they do. I'm starting to second-guess my desire to acquire a Navigator when the lease on this Expy is up next spring.
I told them to call Ford Corporate and speak with one of the engineers. They said "that won't do no good. they don't know shit".
dlcorbett
Air Force
tx
The Jeep Wagoneer (in concept form) will be revealed soon. Depending on whats shown will be my decision when i make it back to the states.
N
NyackRob79
Nyack, NY
Update: they were finally able to pull a code. Driver side front strut solenoid. Ordered the part. Let’s see if that fixes it.
N
NyackRob79
Nyack, NY
Dealer replaced Driver Side Front strut (Ford Part# JL1Z18124D). So far, the vehicle is driving normally and the issue hasn't reoccurred.
This problem turned out to be tricky to pinpoint because the "Drive Control Malfunction - Service Required" error did not log any DTCs, so dealer didn't quite know where to look.
Hope this helps someone down the line.
