2019 EXPY PASSENGER FLOOR CARPET PADDING SOAKED
TomF
Florida
I AM HAVING AN ISSUE WITH THE PASSENGER SIDE CARPET PADDING BEING SOAKED. I HAVE A 19 EXP SSV WITH RUBBERIZED FLOORS AND THE PADDING UNDER IT IS SOAKED. MY SUSPICION IS FROM THE A/C DRIPPING. ANYONE ELSE HAVING THIS ISSUE OR A FIX?
Plati
wouldn't that be a warranty issue?
T
TomF
Florida
WORK COMPUTER ONLY TYPES IN CAPS ....... SORRY
THIS IS A POLICE VEHICLE AND NOT SURE IF THE UPFITTER TOUCHED ANYTHING UNDER THERE.... WHICH MAY VOID THE WARRANTY.
AND SORRY AGAIN FOR YELLING
AAOO
Haha! Just having some fun. Off topic but I just did a little research looking for your problem but came up empty. I did find out that all SSV units come with the 3.73 rear end even though most are 2WD. Interesting...
Adieu
SoCal
Just a guess based on my SSV, but y'all drilled a bunch of holes in the roof didn't you??? Probably what's leaking
Glue wires into plugs, put globs of silicone sealant around it all.
T
TomF
Florida
THOSE LIGHTS ARE WIRED TO THE LIGHTS IN THE FRONT. IT GOES THROUGH A GROMMET IN THE FIREWALL ON THE DRIVERS SIDE
Grey ghost
Melbourne fl
I would see if someone can do a smoke test to locate the leak. Could even be a door seal.
Thanks for what you do,! I'm a retired DUSM. myself. Good luck. On your leak.
Shaffer9
Ms
Does the rear washer spray fluid? It might be a leak in the line going to the back.
StealthyBulldog
Manitoba Canada
Has the windshield been replaced? A previous topic had mentioned it wasn't installed correctly and leaked, although I guess the question should be asked if it is only after a rain or car wash?
Apollo
VA
My expy has the exact same issue....i noticed water stain by the pillar and floor is soaked
Dealer is replacing pillar and roof liner along with the carpet of the truck
They mentioned a drain tube is the culprit...dropping off this week to get fixed...crossing my fingers it solves it
lurch
Boulder, CO
My expy had the rear washer line blow apart at the firewall. It dumped most of the washer fluid bottle into a the gutter that runs along the passenger interior under the plastic door sill trim bits. The carpet was pretty wet as it wicked the fluid.
Apollo
VA
My leak is still there and now going back for the third time.
Any update on your expy?
