2025+ Expedition "Spreadsheet"
BT-152
Henderson, Nevada
Hello, all. Got myself a new (to me) 2025 Expedition Active 4x4, and came looking FORScan guidance. Sadly, there seems to be very little. I have had several Fords before and have dealt with FORScan quite a bit - I helped find a bunch of the 2020 Explorer stuff when it first came out since I was lucky enough to get one early. There is no spreadsheet that I can find for the platform as of yet, so I am setting up a documentation page with what I have found:
If we actually start finding enough stuff to justify a spreadsheet, I'll work on getting it into a normal Google doc, but for now, this was a ton easier considering the relatively minor amount of info that exists. It also has a handy checksum calculator on it just in case FORScan balks like it sometimes does.
If anyone knows of anything not listed, or can confirm anything listed, please let me know on here or by e-mail, and I'll update the page.
BT-152
BT-152
Henderson, Nevada
I tried to get global close to work tonight by modifying the APIM, no luck.
Found a bunch of toggles in the BCM also for global close, turned them all on in conjunction with the APIM change, still no luck.
Someone named Myckel Wiggers on Facebook says he got it to work here:
Unfortunately, he left no information about how. So still unverified that it can work as of now, but just changing the APIM value alone certainly didn't work for me.
Also got an error about unknown vehicle a few times. By the time I thought to take a picture of it, of course, it behaved. It wanted me to enter a part number for the computer installed and contact FORScan. Power cycling the truck a few times got that to go away and recognize it again. Weird. Never had that on any of my previous vehicles.
Mr Big
Tampa Bay, Florida USA
Global close works on mine using instructions from manual:
  1. Press and hold the lock button on the remote control.
  1. Release the button when the windows start to close.
Press the lock or the unlock button on the remote control to stop global closing.
Note: When closing your windows the global closing feature, the bounce-back protection is enabled.See Window Bounce-Back .
BT-152
BT-152
Henderson, Nevada
  2. Release the button when the windows start to close.
Was this after making the APIM mod? Or another combination of mods? I'm not with my truck today to try.
What I did try was what I had seen in the manual I pulled up, which was press lock once, then hold lock for three seconds. I tried that in all conditions with no luck. I can't remember if I tried holding the lock button without tapping it once, but I'd assume the truck would respond the same way anyway.
Mr Big
I
I didn't make any Forscan mods before I used this feature. When I first got the EX, I went through the manual and learned and set all the features, like driver name, seat, wheel, pedal settings, memory set, A/C settings, steering wheel buttons, B&O Unleashed settings, etc.
My method to successfully roll all the windows down with remote:
1: I press the unlock button once then let go.
2: I then press and hold the unlock button for 5 seconds or until all the windows roll down.
My method to successfully roll windows all the windows up with remote:
1: I press the lock button once then let go.
2: I then press and hold the unlock button until all the windows roll down.
* The manual does not say to press unlock once, it just says press and hold until.
The manual also mentions "If equipped"
rugedraw
Miami, FL
You also need to make changes to the DDM/PDM to enable global windows. This is from the 2024 Expo spreadsheet......not sure if anything changed for 2025 in the door modules, but I doubt it.
Mr Big
The gen5 models are total different beasts with different software. Most gen4 sheet's info will not work. This is why there are warnings about using forscan on 25, 36 and 27 models.
rugedraw
Miami, FL
Agreed. However, I don't think the door modules themselves changed. Unfortunately, I don't have the same PTS access I used to have to verify if the door module part numbers and firmware is the same between 2024 and 2025. Comparing the ab data on both a 2024 and a 2025, there are some differences in those lines. I would still try it, but that's just me.
Underwhere
NH
For the parking with DRL, does this just turn on the rear parking lights with it?
Are there even any front parking lights?
BT-152
BT-152
Henderson, Nevada
Is there a 2026 spreadsheet that we can use that shows what has worked?
That's what I've been compiling - everything verified working (and tested and found not to be working). Nothing else has been discovered yet. The only other option is to try lines from older Expeditions or current F-150s and see what works.
Jim622
West coast
I got this off the Explorer forum. Does anyone know if they are the same?
I can test it tomorrow and let you know.
1. To enable “Walk Away Lock”, write each of the following values to the truck and cycle on/off after each value is changed individually:
-BdyCM: 726-89-01 -> x1x1-x1x1-x1--
-BdyCM: 726-89-02 -> x1x1-x1x1-x1--
-BdyCM: 726-90-01 -> x1x1-xxxx-xx--
-APIM: 7D0-09-05 -> xxxx-Cxxx-xx--
2. After the last value is written to the Explorer, you will see "Walk Away Lock" greyed out in Settings -> Vehicle -> Locks in your infotainment screen. Don't worry about it, it's because Ford never intended the Explorer to have this feature, but it will still work!
Mr Big
IMHO, I would not use any codes for as built. I would try changes through simple mode to see if they work and only after backing up, to make sure you don't brick your unit.
Pshemo77
Wroclaw, Poland, Europe
I just read this on the FORScan Forum. It's an older post, but may have some useful info:
Issue of recognizing new Ford models by FORScan
That's true, I can confirm. ForSCAN also works great with Mazda. I also have a Mazda CX-60 as a company car, and I recently connected it to ForSCAN. I got the exact same message: the vehicle wasn't in the database, and the system itself asked me to enter the vehicle code. Naturally, I didn't know the code, but I asked the AI. It gave me a dozen different codes; the seventh one was correct, and I connected to the car's computer without any problems. Unfortunately, the ability to change as-built files is very limited in Mazdas.
BT-152
BT-152
Henderson, Nevada
Any luck?
For the average Joe, absolutely. But if someone is hunting for something, flipping bits is how it’s found - just gotta understand the risks and have good backups.
Jim622
West coast
I haven't tried it yet. I got crazy busy at work this week. I will give it a shot in a few days.
Jim622
West coast
I did get a chance to try it tonight. Sorry to say it didn't work. I had my hopes up too.
So far, nothing that I have tried has worked. I thought we had a new executive order that was supposed to change things like this.
rugedraw
Miami, FL
That has nothing to do with FORScan since it is a third party program not supported by Ford. The problem is that due to cybersecurity changes that Ford made last year, the guy that made the spreadsheets is no longer able to do so. So, we have what we have and whatever we don't have, it needs to be figured out with trial and error like what you guys are doing here.
