People should NOT be trying to enable BlueCruise on the vehicles without the camera to monitor the driver. IT IS A TERRIBLE idea. It is fraught with so many issues. Are you honestly going to trust you and your families life to a HACK? The people using the weight on the steering wheel are morons, and should have their license pulled. As you can tell I am passionate about this. They say they are the only ones at risk, and that is BS, because anybody on the road with them is at risk. If you have driven any of the BlueCruise/SuperCruise/AutoDrive available vehicles you would get it. It needs to have all the nannies possible because these systems are in their infancy. GM's Supercruise is the best I have used to date. Also factor in I own a 21 150 with BC enabled from the factory.@LokiWolf are there any updates to this? Anything adjustable in the APIMs on 2022s yet? Namely adding digits to gauges, bambi mode, stuff like that?
I've been following the brave folks trying to enable bluecruise....
Stay away from the 150 coding, from what I have seen it does not match, not to mention Ford is changing modules left and right because of the chip shortages. I would stick to the drop down options in FORSCAN if they are available for a 22+. Most of what you mentioned should be available if FORSCAN supports your Strategy. Contact FORSCAN support. I haven't been able to plug in to a 22 for any extended time yet. Maybe I will need to go sit on the lot and play with one.And secondarily, anyone know if anything like the bambi mode, global window mode, or auto stop/start disable ones on this spreadsheet work?
thx to Livinitup on the F150 page.Livnitup's FORScan - 2021-23 F150
Module List Module Name - Description,Module Address,Reprogram/Flash Capable,OTA Capable ABS - Anti-Lock Brake System,760,yes,yes ACCM - Air Conditioning Control Module,7C7,no,yes ACM - Audio Front Control Module,727,yes,no APIM - Accessory Protocol Interface Module (SYNC),7D0,yes,yes ATCM - All...docs.google.com
@ExpyNole Sorry I missed this! Yes, but they removed it for a reason on the Heavy Tow, and honestly haven't seen a good explanation as to why they can't coexist. Now Active Park Assist is being removed in general from most that are shipping. My guess is there is another control module that is completely removed. Not just the button. The button wouldn't save them anything, and the reason it is being removed in general is to save chips. So don't think it would be as easy as coding and a button sadly.@LokiWolf Since the HD Tow models lose Active Park Assist 2.0...you think it could be enabled in Forscan if an owner adds the button? Ala when someone adds the trailer brake controller?
I think all the items are there to do it, no?
You have an adapter? If so, plug it up, and read it. If you get the drop down options for the BCM, then it supports that Strategy.I just checked at the Forscan site, and looks like they are up to version 2.3.50 for Windows as of a month ago, with claimed "improved support for 2022 and 2023 MY model". Has anyone experimented with their 2022+ to see if we now have the ability to customize features?
I was asking because I haven't updated my Forscan setup since 2018 when I dialed in my last Expedition. I think I read that once Forscan got to a certain version that it wants an updated adapter that doesn't have to manually switch between the two busses. I was hoping to hold off on investing until I knew we were there, but maybe I'll just take the plunge and see what happens.You have an adapter? If so, plug it up, and read it. If you get the drop down options for the BCM, then it supports that Strategy.
Yeah the classic Elm327’s with the switch really aren’t encouraged anymore. Not even sure they will work at all. Haven’t used one in years. I use an OBDLink MX+ most of the time.I was asking because I haven't updated my Forscan setup since 2018 when I dialed in my last Expedition. I think I read that once Forscan got to a certain version that it wants an updated adapter that doesn't have to manually switch between the two busses. I was hoping to hold off on investing until I knew we were there, but maybe I'll just take the plunge and see what happens.
