Mtparker18
Can someone confirm they'll fit? I've heard they will and they don't.
I dont know tire sizes but with a 3/2 on a 4x4 you can fit 35s on oem rims. After market rims you do need to do some cutting to the lower valence but nothing to bad. On the 4x2's 33s are the biggest.
35 12.5 17
Hey Sol, are you sure about that? I thought 12.5 would be to wide. I thought 11.5 is the widest you can go without trimming. That's like a 305
Sent from my DROIDX using Tapatalk
So now I'm bing told 35's won't fit. So I've decided to drop to a 33" tire. Would 33x10.5/17 fit?
The biggest problem is the rears are going to hit the running boards. I was thinking either remove them or cut them. Plus I'll be running stock wheels, if that makes a difference.
SOL...do you use those lights??? seriously...in ft lauderdale...city lights everywhere...is that just the look you wanted???
