2nd Gen lift glass bracket broke
Discussion in 'Exterior' started by drivepirate, Jul 6, 2018.
  1. drivepirate
    drivepirate Member
    26
    Jan 17, 2018
    PNW
    Hey all! just got back from camping and was getting the kayaks off the roof when I discovered that one of the hinges for the rear lift glass is broken in half! I'm not afraid to fix this stuff myself but I'v never done any glass work and don't know where to start. Has anyone had any experience in this area? My buddy suggested that I try and JB weld it back together but I doubt that would last too long. Any help is much appreciated.
    Thanks
    GG
  2. MrSticker
    MrSticker Full Access Members
    1,289
    503
    May 4, 2016
    Penfield, New York
    Mine broke in 2010 on 2003 XLT. Bought 2 new ones from dealer and replaced them, quick easy job. $125 Can get them on internet from Dorman also.
    Replace both is my advice, one at a time!
    Pop the cap, Torx screw
    (mine was 7 years old when it broke, now replacement is 8 years old ... probably due again)
  3. drivepirate
    drivepirate Member
    26
    Jan 17, 2018
    PNW
    WOW! didn’t even notice the underside and the torx! Thanks so much! MrSticker!
  4. Don Hall
    Don Hall Full Access Members
    87
    191
    34
    Jun 8, 2018
    SANTA CRUZ, CA
    Have glass repair insurance?
  5. drivepirate
    drivepirate Member
    26
    Jan 17, 2018
    PNW
    I have insurance but it’s not worth using. I’ll replace the hinges myself.
  6. Don Hall
    87
    191
    34
    Jun 8, 2018
    SANTA CRUZ, CA
    It's worth using, depending on a deductible, that is why you have it. Doubt that your company would raise your premium based on glass repair claim.
    Checked my glass coverage, and the deductible is $100. MrSticker fixed his problem for $125,
    plus his labor, for a "quick easy job".
    So, doing it yourself should be the way to go.
    Good luck!
  7. drivepirate
    drivepirate Member
    26
    Jan 17, 2018
    PNW
    Thanks everyone. I dropped by the you pull it wrecking yard and grabbed 2 hinges for a total of $18. Problem solved.
  8. Don Hall
    87
    191
    34
    Jun 8, 2018
    SANTA CRUZ, CA
    Good fix....... best on eBay $39.95/used VS $118.80/new. :favorites37:
  9. James McCracken
    James McCracken Member
    46
    17
    May 27, 2019
    Tennessee
    Mine just broke on my new to me 04 I went to LLQ pick a part and robbed the complete window and shocks off of it for $50. Mine was from the north so I am assuming that aided with them breaking. I was not sure if I could just replace the section that appears to be glued to the glass.
    EDIT never mind. I see you're talking about the top hinge not the part the shock mounts to.
  10. NDNplanner
    NDNplanner Member
    39
    17
    Jun 19, 2019
    Albuquerque, New Mexico
    Good call on hitting up the local U-Pull your own parts place. I can't tell you how many little things I've gotten from there that has saved me a ton of cash.
Share This Page
