adamsdaddy
Just bought a 2016 XLT 4X4 with the Class IV tow package. I will be adding a 7 pin. I see the wire tagged elec which I know to be the blue I need for the brakes. Before I cut into the loom - does anybody know if the orange 12 volt wire is also in there? Another old thread on the Truck forum said the orange is only run to the drivers rear door. I looked there but I didn't see a split off wire. I don't want to cut into the loom under the door if the 12V has already been run back to the area around the 4 pin. I also don't want to cut into the loom near the 4 pin if I'm going to end up needing to go buy wire to run the 12V from under the drivers side door.
I ordered the Prodigy P3 to Ford adapter which I thought connected to the plug in the picture.
There is 14 inch wide cooler in front of the radiator - is that the extra towing tranny cooler or just standard?
