ok, i have no 4x4, but read on its a little weird. for no reason one day i tried to use 4x4 and it didnt work. i use it regularly(about 3 times a month) it went to a4wd and that was enough for what i was doing at the time, but it never worked again. i turn the switch and nothing happens. no lights, no sounds or anything BUT!! if i unhook the battery and plug it back up, the a4wd works fine for a about 10 minutes it seems, but no 4x4 hi or 4 lo, and the a4wd quits too after a few minutes. and then i can unhook the battery and it will work again, but only in automatic 4x4. whats the deal? i pulled out every single relay i could find and moved them over one space to see if my 4x4 would start working and something else would failo....btw does anyone know which relay is actually the 4x4 transfercase relay? apparently the owners manual dont want you to know and neither does the haynes.
also, does the transfer case motor have to work for a4wd to work? or is there something internal that kicks 4x4 in and out. if the motor has to work for a4wd to work, then i would think the problem was NOT the motor
please help!!!!
please help!!!!
