97 Expedition stalling, then theft light blinking
P
PO'dexpd'nowner
kentucky
Let it sit overnight to reset the Theft light. Turned key over, no light. Before doing anything else, I tested the #19 fuse to the fuel pump again. Still no voltage so I figured that was a problem and it wouldn't start. Wrong. It started right up and ran for about 20 seconds before stalling. First attempt to restart and immediate theft light. After swimming, I plan on swapping out batteries. Looked up alt diodes this morning and never really found out what or where they are.
I dunno. Can I rule out fuel related issues or is still a possibility?
Captain Morgan
WA
I wouldnt rule it out. Hook up the volt meter to the fuel pump and turn the key to ON, check for voltage. If you SEE voltage there, then watch it while the engine runs. AFAIK that voltage should never go away. When you turn the key to ON, the fuel pump should start to pressurize so that the fuel injectors have pressure to start.
If that voltage goes away, that would be a big GD problem!
The next step would be to test the fuel pump independently and make sure that the anti-theft doesnt cut pwr to it. This infers hooking a cable directly from the battery and seeing that it will run continuously and not get hot and stop due to being faulty.
P
PO'dexpd'nowner
kentucky
just got home from taking the kids swimming. I stopped by a little shop on my road and asked him about this. He didn't know what else to do either. However, he did tell me of a shop that would send the pcm off the $50 to have it tested. I'm pretty sure the pcm isn't the issue but it may give me $50 worth of peace of mind.
While swimming I thinking about this. Code 1147 means no communication between PATS and PCM. If I rule out PCM, that leaves only the PATS module. However supposedly PATS cannot shut down the truck after it's running. Forgive me...just brainstorming out loud here. Am I wrong to conclude it's one or the other or could it be a bunch of other things cause it?
Captain Morgan
WA
You wouldnt be wrong to assume that for $3.50 a gallon of gasoline could solve it.
"Code 1147 means no communication between PATS and PCM"
That looks like it would be problematic.
Keep with the basics so you can eliminate maybe's before doing more intensive things. Measure the voltages for the fuel pump and COPs and see if they get voltage when the things sputters and dies as described above.
P
PO'dexpd'nowner
kentucky
Forgive my ignorance. The fuel pump is in the tank. How am I suppoed to to hook a voltmeter to it? Or are you inferring check for voltage on the wires going to it? Still those wires would be pretty difficult to get to wouldn't they?
That TSB you posted was what the "electrical specialist" gave me...and then told me to take it to the dealer. Can't believe he backed off it. Anyway, the key thing on that TSB is on page 20 where it states that if it is a PATS issue, code 1260 would stored as a DTC. If not there is a power up issue with PCM or ground circuits. Can anyone, off the top of their head, tell me where all the grounds are please? I checked 2 by the battery and megafuses. Checked frame rails but haven't climbed under it yet...well not sense I put the new O2 sensors in a few weeks ago. It was already doing this before the sensors were put in so no to that idea.
Captain Morgan
WA
If you lay under the X on the drivers side and find the fuel tank, you should see the fuel lines, fuel filter and (allegedly) the harness\connector for the fuel pump. You would def be able to hear the feul pump whine if the key is ON.
As for the grounds, you know the mother of all grounds comes off the battery. This is the return rail for all voltage and current in the system. That black cable runs to the vehicle chassis and the connections\lugs must be clean. All power distrubution boxes under the hood and in the cabin are grounded via cables and\or lugs. ALL of them. How many individual grounds are there? I'm not sure even FORD knows.
A bad electrical connection on a distribution point and the PCM is gonna freak out from the eroneous data is receives from other systems.
P
PO'dexpd'nowner
kentucky
I have a few more things to check today.....some wires going down by an A/C pipe and some wires going by power steering pump. I have several TSB's that I'm wanting to look up but can't fnd a website that will let me see the entire tsb...just a summary. I already have the 0162. I'd like to see the 983566, 98110, 962511, 99222, 98241. Anyone know where I can actually view the entire TSB? One site is wanting me to pay but I think it's free if you know where to look.
BTW" took steeing column cover off...no loose wires there.
edit: nevermind..same website is letting me see them
P
PO'dexpd'nowner
kentucky
somehow or another I got the theft light to turn off 3 times by moving wires around over by the a/c dryer. Don't know which one b/c then I'd have to walk around and see if it was still flashing. It could have went off on its own afte 2-3 mins of flashing but I never noticed it go off on its own before. However, it was still tripped b/c it wouldn't start and when I cycled the key it would be right back on. May have to get one of my kids to sit in it to tell me exactly when it goes off.
P
PO'dexpd'nowner
kentucky
yes....every morning when I start it, I try the other key...keep changing them every day. Yesterday I kept it revved up to about 2200 rpm's and it lasted for 44 seconds and then instead of stalling it stumbled, came back for a escond, then stalled.
Talked to another shop and was told this: "Ok..hmmm. So I can spend hours looking over it and either waste my time or your money. I'm not wasteing my time when I got these other vehicles lined up."
Still couldn't find the TSB's to look at. Any ideas for those?
Captain Morgan
WA
In that scenario, did the Anti Theft light come on? Were you unable to start it again for X amount of time?
P
PO'dexpd'nowner
kentucky
when it stalled, no theft light. Turn the key back and try to restart, theft light. Still had to wait overnight.
P
PO'dexpd'nowner
kentucky
New development today. Been sitting for 2 days and will not start. Even at the beginning the theft light is staying on. So something finally went kaput?
I never swapped batteries...forgot about it. But lights always go out when cranking. I don't think any other vehicle of mine has ever done this. Could it be battery? But that wouldn't trigger the theft light would it?
Starting to feel kinda stupid here....like I'm talking to myself.
Captain Morgan
WA
Remove the battery posts for 30 minutes and clean them.
After 30 minutes, cinch down the posts and put jumper cables on another vehicle and start the b$##@!d. If that anti-theft light comes back on, and it wont start, we know the answer costs about a buck seventy five.
P
PO'dexpd'nowner
kentucky
unhooked battery all night, charged it up, wouldn't go past 68% (truck voltage meter was showing fine)....will have to get it replaced. Went ahead and hooked it up though to test....theft light on. Actually read a thread a week or so ago where a theft light was on and kept draining battery....doubt if I could find it again.
PCM is sitting in front seat of my car to get tested. This is one aggravatin' ****
Captain Morgan
WA
You can't accurately diagnose an intermittent issue as long as there are variables that change constantly. Way back there was discussion of checking the battery and cleaning the posts and all other connections.
Until you get that stuff out of the way and perm eliminate it as a suspect, you'll constantly be tripped up by it and waste voracious amounts of time.
I feel your frustrations.
P
PO'dexpd'nowner
kentucky
Ok...brand new battery, sand papered the connections, different pcm, same ol' story...theft light, no start. This absolutely is not a pcm issue. Just got back in from the 100 degree heat and am not happy.
I was wiggling the wires under the steering column abd this onuvabitch pops off and I can't get it back in. Do this go to the PATS receiver? It goes right up next to the ignition switch but I can't get it to lock into place and don't know how to pull the ignition. Anyone know for sure what it is and how to get back into place?
I may take $1k for this SOB if I can't get it going soon. Scrap will be around $650.
P
PO'dexpd'nowner
kentucky
Well it's been a while. I planned on towing it the huge dealership 25 miles away but my uncle told me to wait and have his guy look at it. Unbelievably, it fired right up for him today when he made a house call and ran for 10 mins vs the 20-30 seconds it had been doing. he said the fuel pump was not working after it shut down...not coming on. So...really that doesn't tell me anything does it? Once the theft light trips, I already know the fuel is getting shut off.
Question: tow to this guy and let him try it or go straight to dealership and get *****?
Captain Morgan
WA
Err, hows your sex life?
Seriously, I thought you would be posting pics of the big bonfire by now.
If this guy has real old timer mechanic experience, give him a shot at it, or just GIVE IT to him.
You could print out all the stuff we've covered in this thread and all the stuff you've tried, but why ruin his day like that?
Notmyidi
oklahoma
Id have directly wired around all that theft light ******** with some relays and a key on source feed
Here hoe bout this, large pink with a black tracer (stripe), apply power to that wire, of the fuel pump comes on, start it, see how long it runs
I know you just want to fix the modo, but part of owning a old vehicle some times
Personally is get the appropriate relay amp, and fuse or a resettable circuit breaker wire it down wire of the inertia switch (btw did ya check that? ) or use inertia switch as my signal and apply power to the pink on a key on only source
And been on my way for about 60 dollars max
sent from my mind via telepathy
