99 4.6 xlt dead?
stamp11127
Temple, Georgia
You can determine that by using voltage drop testing on the starter solenoid mounted on the firewall. If you have 12v going in and 12v coming out of the big studs then you test the cable going to the starter. If you have 12v there then it is either the starter or the solenoid on top of it.
P
popeye47
Delta Bc Canada
Expy dead
When it won't start get someone to gently tap the solenoid on the starter while your trying to start it and she fired right up
1955moose
You guys keep saying solenoid on starter? Does he have one besides the one on the pass side firewall. My 2000 expy doesn't
Solefly87
South Carolina
The starter has a solenoid mounted to it.
stamp11127
Temple, Georgia
Most if not all starters will use a solenoid to operate the shift lever inside the starter. The lever is used to slide the Bendix or pinion gear forward to engage the flywheel. There may be a second solenoid mounted on the firewall whose only purpose is to control the high current side of the starting circuit.
Bedrck47
Elizebethtown, PA
The first pic is of a 1st gen starter circuit
The second pic is of a starter motor with the solenoid mounted
The third pic is of the starter relay which is mounted to the firewall sometimes it is also referred to as a starter solenoid
These components should be on all 1st gen expeditions
1955moose
Well shut my mouth, I've always worked on earlier fords, and have never poked around my new/used SUVs starter. Looks like a smaller version of General Motors starter. I'll have to crawl under my truck more. Was his problem with the starter solenoid, or the firewall unit?
Bedrck47
Elizebethtown, PA
Sorry Moose I can't shut your mouth at least until you take your foot out.
Have no idea which unit he repaired
1955moose
And I've got big feet. Hard to pull out! That made me smile, I needed that bedrck!
1955moose
Well all you guys working on your expy's and f150's thinking about you as I pound down my Coronas at Lake Merced here in San Francisco. Rained real hard last night and is too cold to bolt up new rear calipers. That will have to wait till it drys and warms up. Cheers!
1955moose
Ah a success story, cool, glad you found problem, Moose.
