suthern kumfert
I am guessing I have a tensioner or guide that has failed cause I am getting noise from the passenger side timing cover area. I have a few question that I hope you can help me with. First off is it ok to just replace the tensioners and guides and not the chain and sprockets? (don't have the tools to hold the cams in place so was thinking maybe not replacing them) Second what is a good timing kit o buy to do this job? (I have seen some a couple hundred and then others around 60 bucks) Third, any advice, tips or tricks you may want to pass on to make the job a little easier?
Thank you in advance for any help
