Look ok? Did you put a test light to both sides with the switch in its respective spots, or ohm out the fuse itself?
Check the under hood fuses, wanting to say there should be a relay
Flash high is se.ding voltage down both legs of bulb, dual filament so its a 3 wire plug, grnd, high and low.
Got running lights ? (park lights), gauge cluster lights?
If yes to both I'm voting a multi function switch (blinked arm itself.)
Couple ways to.test this theory
A jumper wire,
A test light
Or the good old throw parts at the problem fix.
I'd use a combo of the first two. If your able to get the shroud off from around the.column, based off most Ford's the plug on the top is blinkers and hazards (might be two seprrat plugs)
Break out the test light and a pad and pen. Go around sticking the test light in the back of the.plug til it contacts the rear of the terminal. Operate the the multi function switch (mfs from now on). Right now what wire gets power to it with each function.
You should have a constant power as well as. Ground, these test are key on btw,
When it comes to the wipers it wire will probablybmake the bulb light up brighter as you turn it up because the wiper.switch is both a variable resistor and a time function. Anyways
Or Gould note the wire.colors at the bulbs and pray to everything holy that they are.the same at the msf.
When you find that you have.several dead wires (make sure you checked.washer.spray to)
Make a jumper with a inline fuse (start out with a low amp fuse just incase your.wrong, but rated for the circuit your testing works fine to) Jump power to those in the terminals with the plug unplugged, now your bypassing the.switch, if they come on in high and low respectively on diff wires. Your switch is bad, if they don't well then...
You can do the same with the headlight switch.
The headlight switch handles the current but msf transfer the power where it needs to go, ie high or low.
High flash isn't used a lot so the.circuit within the switch rarely ever deteriorates. Each time a switch is thrown, befoe it contacts physically an arc of electricty "jumps", when this happens it burns the contact depositing carbon. Eventually there is no longer a surface for it have continuity. That's how most switches "die"
Be careful, if its over your head, get a diagram, or just get the part and try it out, wat are returns for otherwise?
Side note you may and probably will haft to remove the steering will to.get to the bottom bolt of the mfs
When I get to work ill thumb through one of our books and see if I can get a wire color for you, no promises though it'll be from an econoline, you'd be suprised howbmuch is the same from model to model from a manufacturer
Anthony
sent from my mind via of telepathy
