a/c blower
piumber67
san antonio
My A/C blower in the front comes on & off. I put in a new motor put it dose the same thing. Not sure what's going on.
Bedrck47
Elizebethtown, PA
The blower motor is inoperative — EATC
Fuse(s)
Circuitry short/open
Blower motor relay
A/C blower motor
EATC module
A/C blower motor speed control
BJB
The blower motor does not operate correctly — EATC
Circuitry open/shorted
EATC module
Check the ground connections behind the front kick panels (both sides) make sure they are clean and tight.
rwmorrisonjr
Memphis, TN
Check the thermostatic controller since they go bad. Its located on the side of the blower motor housing, and replaced in about 15 minutes. About $40-50 from the dealer depending on manual or automatic climate control.
Bedrck47
Elizebethtown, PA
How do I no if I have manual or automatic climate control.
Check in your owners manual as it will show you the different controls for either manual or automatic climate control.
If you don't have a owners manual you can down-load one from
owner.ford.com
