A couple of questions on the expedition
Gabriel99
Hey i recently got a 1998 Expedition xlt with a 4.6 2wd and i had a couple of questions about it. Sorry if i come off as ignorant i just dont know and want to learn more about my car! thanks .
1.) do all expeditions have key less entry?
2.) do all expeditions have the auto dimming slider
3.) do f150 2wd long tube headers fit on the expedition as long as they are for the 4.6 and same year?
4.) what are some other things i should know about the expedition
5.) is there any way of lifting the 2wd verisons? as well as what are some nice shocks to improve ride quality
ExplorerTom
Colorado
His is 2wd..... it’s a car.....
1) don’t know
2) don’t know
3) yes.
4) probably
5) 2wd’s are easier to lift than 4wd. Spindle lift, springs......
All Expeditions are cars technically, at least that’s what I’ve been told by pickup drivers LOL. SUV is the correct term, it’s a truck based suv. I refer to my 07’ 4WD as a truck often but I’m incorrect. I also refer to it as a car as well occasionally. Pickup drivers always get offended when you call these a truck....
A truck is defined as having a flat loading surface. Although our cars or trucks or whatever you call it are actually much heavier than your typical truck. I had a guy get angry with me discussing curb weights and his manhood threatened when he realized my Expedition is 750 pounds heavier than his F-150!
Flexpedition
midwest
No, not all had keyless. Easiest way to find out if yours is equipped is to insert the key into ignition and turn it on to accessory and then back to off -- do this somewhat rapidly, 8 on/off cycles within 10 seconds. If the truck was equipped with keyless entry, then after the 8th on/off cycle the door locks will cycle themselves and you'll hear a tone.
No. If you don't have keyless entry above, then you probably don't have autolamps. You are talking about the second wheel next to the dimmer wheel in the headlight switch assembly, right?
Not sure
You shouldn't lift a 2WD.
See #4.
Adieu
SoCal
So.... is a pickup with a "camper" still a truck?
Is an Expedition with seats folded and a tarp laid down a truck? Does it matter that a real roof makes a better camper?
PS f150 doors are undeniably cooler, though
Expedition interiors are so much nicer than the F-150 though, at least on 2nd and 3rd gens. Not familiar with gen 1. We get a lot of Super Duty styling and panels instead of F-150 ones. We also get washer fluid indicator, separate tweeters standard etc.
TobyU
Ohio
Why shouldn't you lift a 2wd? Just personal preference?
They all look better up higher with bigger square cut tires.
Plati
Mine is a truck. Actually ... Its a Truuuuuk. Big heavy vehicle built on a truck chassis for transporting materials and towing. Large powerful engine. Sucks gas like beer pong tournament sucks beer. What car can you fit a 4x8 sheet in? I can load a dozen garbage cans in it for the annual dump trip. Try that in a car.
Mine is also a camper. Its also a floor wax AND a dessert topping too for the older people who remember that SNL skit!
I understand the 2wd thing, but Semi's aren't 4wd
lbv150
Northeast
In our family we always refer to our Expys "trucks" along with our pickups. The Mustang is a car and the Jeeps are jeeps.
TallCowboy
Fort Hood, TX
Mine's a truck also.
It can do pretty much anything a PICKUP can do.
And both are "trucks" for all the reasons noted above.
Go read the 400 or so threads about this discussion. ;)
