ABS Light Issue
ghettoracer
Oregon
I have 97 EB Expy, recently changed the brakes on it, new rear calipers and pads, front pads and re-lubed the whole thing. I didn't bleed the fronts but I bled the rears. While driving a couple miles the ABS light decided to come on. The first time the ABS light came on was a week ago before I changed my brakes and it was still cold out like today was when it came on. I still could brake and stuff. One of the rear calipers was stuck so it caused some dragging thus the brake job. When I turned off the Expy and turned it back on the light stayed off. I took my truck in recently to have Ford install a speed sensor recall with a jumper. Could it be the jumper or one of my ABS sensors are bad or should I bleed the entire braking system and see if that is the culprit? thanks in advance.
G
ghettoracer
Oregon
This is the recall I was talking about:
Vehicle Make / Model: Model Year(s):
FORD / BRONCO 1994-1996
FORD / EXPEDITION 1997-2002
FORD / F150 1994-2002
FORD / F250 1994-1999
LINCOLN / BLACKWOOD 2002
LINCOLN / NAVIGATOR 1998-2002
NHTSA CAMPAIGN ID Number: 05V388000
Summary:
ON CERTAIN PICKUP TRUCKS AND SPORT UTILITY VEHICLES EQUIPPED WITH SPEED CONTROL, THE SPEED CONTROL DEACTIVATION SWITCH MAY OVERHEAT, SMOKE, OR BURN.
Consequence:
A FIRE AT THE SWITCH COULD OCCUR.
Remedy:
BY LETTER DATED SEPTEMBER 12, 2005, OWNERS WERE INSTRUCTED TO RETURN THEIR VEHICLES TO THEIR DEALERS TO HAVE THE SPEED CONTROL DEACTIVATION SWITCH DISCONNECTED. OWNERS WHO HAVE HAD THEIR SPEED CONTROL DEACTIVATED ARE BEING NOTIFIED THAT PARTS WILL BE AVAILABLE AND ADVISED TO MAKE AN APPOINTMENT TO RECONNECT THE SPEED CONTROL BEGINNING IN FEBRUARY 2006. OWNERS WHO DID NOT HAVE THEIR SPEED CONTROL DEACTIVATED ARE BEING NOTIFIED TO HAVE THEIR SYSTEM REMEDIED BEGINNING IN FEBRUARY 2006. OWNERS ARE URGED TO AVAIL THEMSELVES OF THE FREE DISCONNECT SERVICE AS SOON AS POSSIBLE BECAUSE OF THE SIGNIFICANT RISK OF FIRE. OWNERS MAY CONTACT FORD AT 1-800-392-3673. (NOTE: ALSO SEE RECALLS 05V017 AND 06V286)
Notes:
FORD RECALL NO. 05S28. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
aircargoo
new jersey
i think its a sensor....i power washed my under carage once...put a heavy spray of water all over brakes from back of rims.....
this caused light for abs to come on.....went off after a day or so.
there not expensive i HEARD....never know thou. change all 4 if cheap:cool:
sensor light i dont think has nothing to do with calipers,pads,ect....start with the side u said was sticking....prob. got hot there.
G
ghettoracer
Oregon
I did the recall of the speed sensor, and hasn't came back on. Thanks guys!
